1 - 10 of 10 Posts
i need to wire my vert top switch.i installed a new painless harness for the entire car.i have the origianl wires from the switch to the pump.my question is how should i wire it?do i use a relay of some kind or a fuse?if its a relay what kind should i use?i know i shouldn't wire it directly to 12v.any help would be appreciated.
There is a relay on the firewall (30 amp, Ricks sells them). It can be seen in this pic at about 1:00 from the power booster:
http://www.stratagaz.com/67L30M20/L30M20-L30M35091304.jpg
A #12 or so wire goes from the horn relay to the breaker on the firewall. Another #12 or so wire goes from the breaker through the firewall and a rubber grommet to a plug. Three wires including the wire through the firewall come together and go to the switch. Two wires then continue back to the motor.
If your motor is in good shape and the top moves freely you will, that's how they came from the factory. Beleive it's either a 25 or 30 amp circuit breaker.
1 - 10 of 10 Posts
