I need to install my front corner lights on my 99 camaro. I'm not quite sure on wat to do here. If anybody can give me sum advice or point me in the right direction it would help out alot. Thanx
WHAT YOU'LL NEED: a 7mm & 10mm wrench & socket.
step 1. buy a 4th generation camaro
(congratulations on your very wise decision to buy a nice car and 2. replace the sh.itty corner lights.)
step 2. pop open the hood and remove the headlights (be advised youll need a 10mm socket for that)
step 3. with the headlights in a secure place, start off by unscrewing the bulbs that go into the corner light.
step 4. unscrew the bolts with a 7mm socket (there should only be two)
step 5. remove the old corner lights by gently pushing them up towards you.
step 6. clean the housing for the new corner light so it looks SICK.
step 7. install new corner lights, put the bulbs on first to make sure they fit in correctly
then screw the bolts back in and install your headlights again.
THIS SHOULD TAKE ONLY 30 MINS TO DO. I JUST DID THIS 2 HOURS AGO BY MYSELF! GOOD LUCK
