1 - 17 of 17 Posts
I am beginning to assemble my 406 and measured the rod bearing clearances at .0021 to .0023. I plan to use the engine mostly on the street with a few trips to the strip a year. Hoping to make a little more than 500hp and rev to 6500 RPM.
The book I have says .0017-.0030 for a Stock engine, .002-.003 for Hi-Po Street and .0025-.0035 for High-RPM Racing.
My clearance seems to be on the tight side. Should I increase the clearance? If so, how?
Matt
You could get oversize bearings. Or you might be able to get the crank polished a little .
Personally I wouldn't worry about it, you are in spec......and tbh 6500 rpm isn't a lot of rpm.
i personally run those clearances but i run 30 on back main ( alittle less oil pressure but it makes more power because of less rotational drag
Matt
Your clearences are PERFECT
Assemble it, then rod the piss out of it!!!
Thanks guys. I will run them as they are.
I checked the main bearing clearance and have .0021-.0024 on the first 4 and .0036 on the rear. I think the .0021-.0024 are a little tight and the .0036 is a little loose. Is that correct? Should I get different bearings or run it like it is? I heard somewhere that you can scotch brite the back side of the bearings to make them a little thinner and then install them to get more clearance. Has anyone done that? Will that reduce the bearing crush and cause a problem?
Thanks again for all the help,
Matt
Matt
Your clearances are good for start up. Use good oil and break it in slowly. Leave the scotchbrite trick for the pro racers. I usually call .001-.0036 good. I would check the rear crank flange thrust clearances. Thats between the crank flange and main bearing thrust surface. .005-.007 is my number. This is especially important on a manual trans car.
Discussion Starter #8
Don,
My thrust endplay is .0035. Any way I can increase it a little?
As for the bearing clearance. I have been doing a lot of searching on this site and find that some people like to run around .0035 for the mains and others prefer .0025. I have learned that a larger clearance will cause more oil flow through the bearing/crank journal interface and cool them better. What is the advantage of the tighter clearances. What is the draw back to running larger clearances?
Matt
Matt
Nah, the thrust bearing can handle the larger clearance. Matter of fact I set mine up in that fashion. You are good to go, imo.
bearing clearances fine i would run that way --dont like that much thrust clearance and wondering why if its new or reground--too much clearance will make it sling a rod at high rpm--if you dont turn 6600 rpm or higher i think it will be fine=the more bearing clearance you have , needs more oil volume and it will have lower oil pressure at idle but yields more hp--too tight more friction less hp and can kil a crank higher oil pressure--i wouldnt run a 3 or more accross the board for the street
Discussion Starter #11
My thrust endplay is only 3 1/2 tenths. I thought that is too little not to much.
.0035 is three and one half thousanths. The rear main being that loose will hurt your hot oil pressure at idle. Sounds like you could order a different rear main bearing that is a little tighter bearing wise and loosen up the end play a touch.
Discussion Starter #13
Todd,
Thanks for the correction. You are right. 3 and 1/2 thousandths. How do I loosen up the end play a touch?
Matt
I was thinking you could order the new rear main with a little less clearance on the bearing surface and a little more clearance on the the thrust.
Discussion Starter #15
The book I have on building a small block says to hit the crank with a soft hammer to seat the thrust. I did that and got .0035 clearance. I then heard that you have to hit it with something more substantial. So I hit it with a big brass hammer and now I have .0075 clearance with the main cap only hand tight and .0055 with it torqued to 80 lb-ft. Is that enough clearance.
Also, the local machine shop said the rear main clearance may tighten up once I install the oil pump. I will try that out. I thought it would increase the clearance but they say it will reduce it. I will see.
Thanks again for all the advice.
Matt
lol--just a light tap front and rear seats it in--oil pump aint gonna make a dif--gotta get
a different main bearing --what kinda crank is this new or re-ground
Don,
Matt
Thrust clearance is good, if you got more clearance after you tapped it, , all you did was seat flange a little more. I have run larger clearances before but that was a drag car with a 3000# long style clutch. Remember when the clutch is depressed, you are putting that pressure on those thrust bearings.
I even went to the extreme of making sure I had plenty of oil in that oil cavity. I made a little eproxy filled dam, just to cradle oil . You are good, just put it together.
You did not mention if you are running a plugged filter bypass. I dont like them, but many do . Have tried it both ways with a napa gold filter, could not see the differance but I could hear the oil pump labor more when cold.
1 - 17 of 17 Posts
