I've read a few posts regarding original and correct flashers for a 1969 Camaro and need some further clarification.
Signal Flasher (located under dash near the ashtray), is it rectangular or round/silo style or either? What are the correct ink stamps or metal press stampings (DOT?), painted or natural? Who were the original manufacturers? Tung Sol? (see example below)
Hazard / 4-Way Flasher (located in the fuse block), is the round/silo style only correct? What are the correct ink stamps or metal press stampings (DOT?), painted or natural? Who were the original manufacturers? Signal Stat? (see example below).
Lloyd, one thing that can help us to help you when you post photos, reduce them down to around 880x660 so they are viewable without scrolling side to side or up and down. Makes it alot easier on old eyes too. Im going to move this to Elec. section as well. :)
I have always seen
a round short flasher on the fuse panel for the emergency flashers
and a round can 512 for turn signals.
OK, will do.
