Does anyone know the correct torque I should put on new u bolts on my 12 bolt rear end? I torqued them to 75 ft lbs but wasn't sure if that is enough. Thanks
I use a 8" wrench and use the german torque method goot n tite never had a problem.
Tightening Torque Guide for Grade 5 & 8 Hex Cap Screws
GRADE 5
GRADE 8
Coarse Thread
Coarse Thread
Size Clamp Load Plain (ft. lbs.)
1/4-20 (.250) 2025 12
5/16-18 (.3125) 3338 25
Or you could look in the Chassis Service manual for the listed value of 40 foot pounds of torque once the anchor plate is leveled with the spring perch bottom.
Big Dave
Thanks Big Dave I've rebuilt and installed them years ago but forgot what torque. Should I back them off to 40 lbs?
