I just installed a new complete poly bushing kit for the front end of my 69 camaro. What is the correct way to torque all of the hardware? Should it be with the weight of the car on the wheels? I thought that I heard that with poly bushings it did matter because they have the metal sleeve in the middle, but I am not sure. I also need the torque specs for the swaybar mounts, cross shaft ends, upper and lower control arms mounting bolts and the bolts that mount through the upper control arm cross shafts. Thanks for the help
