should bolt right up.
355sb, vortec heads, HOT cam,T-10 tranny, 3.70 gears 16" IROC wheels
Discussion Starter · #3 ·
I tried to install it and I guess the plastic on the corvette wheel is long because it has telescopic. The turn signal lever on the Camaro column prevents the wheel from going on. It seems as though if the shaft was longer on the Camaro, it would work. Do you know of any adapters or any thing I can do to make it fit?
