Courtesy lights that go under dash near kick panel. Where exactly do they mount?
I see the wire harness is available along with metal brackets the bulb socket goes into
The harness has a connector on it (red & white wires), where under dash does this plug into?
Not seeing any open plug to receive the harness
Harness:
https://www.npdlink.com/product/harness-courtesy-light-under-dash-oe-style-repro/110869?year=1967
Bracket:
https://www.npdlink.com/product/bracket-courtesy-light-dash-installs-under-dash-to/108444?year=1967
Al - Waterloo, Iowa
You may or may not have the plug on your car. If not you have to splice into the
harness. There is a multi connection plug for the rear wiring harness (includes
dome light orange and white wires) under dash on drivers side clipped to the
back side of the dash. It's a bit difficult to get to. The light brackets mount to the
corners of the dash lip via screws. You should have holes in the lip already.
Here's a thread describing location of the plug if you have it.
https://www.camaros.net/forums/19-electrical-wiring/154745-underdash-courtesy-lights-revisited.html
Thanks Guys
I am not seeing orange/white wire coming from or going to the top of the DS kick panel. There is a taped wire harness going down into it so maybe the plug is off of that and "behind" my DS kick panel. I will pull kick panel and look.
I have option RPO Z21 style trim group and Z23 interior décor....IDK if either include "courtesy lights". IDK if glove box light is part of the courtesy light group but I have that and it is not the "add on" harness that plugs into "BATT" on the fuse block
if no connector I guess tap into orange wire (+12vdc) for glove box light and to white wire (GRD) of door jamb switch
I really never gave this mod any thought until I sat in a friends 67 with the lights and they "help"..... with black interior, black sun glasses falling on carpet....yeah a little light will help :)
Well no Courtesy Light connector behind DS kick panel.
Tapped into orange (BATT) wire under dash and white door switch wire. Easy. Nice addition to the interior lighting.
Got the harness, brackets and bulbs at the local, to me, NPD
