I have a 1969 SS396 with a Edelbrock RPM Performer intake and a Edelbrock 750cfm Carburetor (#1407). I am looking to add cowl induction air cleaner on it. I have the cowl hood and was wondering if anyone else was running this setup and if it had any clearance problems with the hood.
Thanks,
Greg
You should be fine.....my small block doesn't even go up in the cowl on mine. Just make sure the motor mounts are the correct ones for your engine
68 RS, Ash Gold,pwr windows,Hounds tooth,355/T350,Autometer guage pod
I have the proformer Rpm intake and the 600cmf carb with a one 1in space and a 3in tall air cleaner and it just bearly sitis in the cawl. You will have tons of room. I have so much room I am going to ad a 2in spacer to raise it up some more so i can get a cold charge.
Discussion Starter · #4 ·
Thanks a lot guys. I was thinking I should have enough room, but with the cowl induction parts costing so much, I wanted to be sure before I ordered them.
Greg
I have a 396, Edelbrock Performer 2.0 manifold, Holley 750 DP with a 1" spacer, cowl induction hood. It's close on my hood. The wing nut would just touch the hood when the engine torgued.
I replaced the wing nut with a standard nut; no problems at all now. Just make sure the carb stud isn't too long.
Joe
69 396 w/SS Trim
[email protected]
69 Pics http://albums.photopoint.com/j/AlbumIndex?u=1506559&a=11674961
