Hey guys, I recently received the CPP 500 series steering box, master cylinder & 11" booster (4 wheel disc setup). The master cylinder kit and brake booster seem all setup and ready to go (minus the paint for MC).
When I try to bolt the booster to the firewall, the bracket sits about 1" from the firewall because the round plastic part that looks like it should go through the firewall is a little too big. If that round plastic part would fit through the firewall, everything would bolt up nicely. Is it just a matter of widening the hole it is supposed to go through? Or is there something I'm missing? I can't seem to find information on this, all the videos I've found make it look like a simple bolt up install.
Thank you!!
Thank you!!
