So you're getting an engine and distributor with VA but told not to use it?
Craig,I have a BBC 454 in my 69. It's a little tired and I'm thinking about replacing it.
I have been looking at crate motors, I would love to get a 427 but the only one I can find is GM Performance and it is a little high for my budget.
I see crate motor from Blue Print and ATK. does anyone know anything about either of them? Or can anyone suggest a different supplier.
I'm not looking for big cubic inches, Like I said I would prefer a 427 but if I can't find that I'll go with a 454.
Craig
I have had 2 69 Camaro SBC cars this is my first BBC, so I want to keep it that way. I know a lot of people are going LS but my 70 Camaro has a LS motor and I don't two of the same car.Are you set on a BBC because it's easier / less expensive to install because that's what you have in there now? If the car's a cruiser, personally I would choose a roller cam'd SBC with EFI. You can get better fuel economy, and still plenty of oomf. Pretty easy to get 500 ft/lbs of torque out of a SBC and still get reasonable fuel economy. A BBC looks nice under the hood just because it's big but for a street car you really don't need more than 500ft/lbs of torque to roast the tires and have lots of fun.
What ever you choose, as far as not using a vacuum advance, you can always change the tuning on the engine delivered and set it up to use the vacuum advance, you just need to know what you are doing and set it up so you aren't risking detonation. If you aren't comfortable doing it find someone to tune it for you. You may not get the numbers on the dyno sheet but the change probably won't be noticeable unless you are looking at 1/4 mile ET or something anyway.
