1 - 14 of 14 Posts
Switched mono springs to 5-leaf (off Craigslist) and fabricated some spacers to make up spring perch difference. Drove +/- 700 miles hoping car would settle or something! Passenger rear side is 3/4" higher at fender opening than driver side. I'm usually the only one that can see it. Original front springs. Driver front slightly lower. Mine is a low horsepower cruiser that won't break traction. Can I just insert a lowering block on passenger side to square this thing up?
Yes, you can, or, if time on your hands, swap springs per side and see if problem follows.
Thanks for checking in. Putting this thing back together was a tough task and it is hard to go backwards at times! I was hoping somebody would bless my idea of tricking it back level. I don't think I can switch the leaf springs in the current Virginia weather in a hot shop! Too fat and old! I'm also cheap, so getting some shop to re-arch the springs isn't a plan, either. Don't know how thick a lowering block I need for it to show up at the fender opening as 3/4". I guess you experiment and then find out the problem was a tired drivers side coil!
Scott
May ROTM winner to boot! Cool.
Make sure you drop the car on the ground prior to tightening up the leaf spring mounting points. There have been a few prior threads where this corrected uneven rear ends.
Thanks Mike - I was up to speed about that.
I tried to "pull" it down by loosening the shackle bolts, loading the trunk with a tractor weight on that side and retightening. I'm not insane about curing this, but it is not going away with time!
Scott
First thing I'd do is loosen the mounting bolts, bounce it up and down, push it up and down the driveway, bounce it up and down, tighten everything back down and see if it settles.
When I had leaf springs, this didn't help, so I ended up with different height loweing blocks on each side to make it even.
Then it's settled (I did plenty of the bouncing and wishing)! I'll put a some variety of lowering block in on the high side and take some new readings. Sounds like this is not uncommon. Thanks everyone.
Scott
What is the condition of your subframe bushings? Are they all the same thickness in their current state?
Don
Then it's settled (I did plenty of the bouncing and wishing)! I'll put a some variety of lowering block in on the high side and take some new readings. Sounds like this is not uncommon. Thanks everyone. Scott
Thank you, Another action I did was put three 1 inch spacers between the front spring eye mount and unibody with longer bolts - on the lower side.
The only problem with this action is one can see the front half of the spring. Bit mine was a qtr miler and who really cared ...
The front half of spring locates the axle, the rear takes the weight.
Discussion Starter #10
Yo Don,
I repaired the subframe holes and replaced all the bushings with original style rubber/plastic. You are right to consider this a problem because my lower rear passenger bushing split a bit after the final tightening! Naturally I was pissed, but it wasn't completely wasted or weird. I will change it out, but I don't think it is provoking all of the twist. I hate that I will need to buy the whole kit just to get the 1/2 bushing. Rick's (if you are listening!), you should send me a new one...
Yo Don,
Different heights on the bushings can cause the car to lean....
Don
Discussion Starter #14
I've traced uneven rear height to an uneven front end. Put a floor jack under the frame (not under the control arm) driver's side front and jack it up until the front sits level, then recheck the rear.
I can do that. I've simply lifted that low front end and can see that diagonal relationship to the rear. +100 degrees in Virginia, so I'm enjoying working on just the theories for the next several days! Thanks!
1 - 14 of 14 Posts
