CFI runs fine. It was better then those feedback q-jets. It’s usually the knucklehead with the wrench that messes it up. Troubleshooting is no different from any other kind of TBI/EFI setup. It isn’t a space ship. We fear the unknown. :noway:
But there is some good info here. I’d go to town with a can of carb cleaner & look for vacuum leaks 1st. Indeed look at it idling with the air cleaner off. Turn key off & look for drips. Scan codes (no check engine light)? To check fuel PSI, you have to tap the feed line between the filter & the RH injetor – I actually added a gauge inline, like guys do with carbs. I forget the stock PSI (13?). I can try to look when I get home, but my 82 TA manual is in many pieces now thanks to CFI. I’m not sure I could find the page.
Vacuum leak.
Injectors
Coolant temp sensor.
Map Sensor
Bad fuel pressure regulator (in rear TBI unit)
Bad IAC <-- I had these kick my butt for months – parts store gave me wrong one with wrong pintle cap.
Throttle Position Sensor
Look here too:
http://www.aces.edu/~gparmer/efi/
http://www.x-ram.com/commonproblemswithcrossfireonlyinjectionsystems.html
I also have a link to a CFI forum at home, that I can get you.
Prowl EBay for manuals, really any 82-84 Camaro or Firebird would do (probably more useful then the vette one). A paperclip & multimeter can go a long way. Or a used OTC or similar scanner. When we upgrade our scanner at work, I used to drive around with the old one plugged in, just to see what was going on.
Former mid 13 sec CFI Trans Am owner. I might get another one someday, just to prove people wrong. I’m sure I could dip it in to the 12’s now.
