I'm still in the planning stages of an LS/T56 swap into my 69. Leaning towards GMP crate Hot LS3 with engine controller and harness. Will the ECM and wire harness support cruise control? If not, what would it take to add CC to it? Thanks.
Interesting, I'll look into it. ThanksFrom what I understand, you will need to deal with 'tuning' afterwards with the PSI or another computer besides GMPP. I was told the PSI computer would get me running but then I would still have to find a tuner and get it dialed in. I chose the GMPP parts so I didn't have to deal with that.
Realistically, if you tell PSI what crate motor your buying I can't image they don't have a tune for it that's right on. GM is selling a ton of these engines and if you leave it alone they should have pirated GM's tune by now.
I spoke to the guy a PSI a few times, he's very helpful and knows his stuff. Best bet would be to call.
Spankys Rod shop does a cruise control that should work with the GMPP harness.
http://spankysrodshop.net/index.php...-control&catid=16:engine-accessories&Itemid=7
