hi all i just painted my upper and lower control arms using eastwoods rust encapsulator and topped off with chassis black gloss. i put 1 coat of RE each waited an hour then did 3 coats each of chassis black waiting 15-20 minutes between coats and then hung them up in my garage to dry. the weather was warm about 65-70 degrees. today i went in to check them out and they feel "soft" to the touch but not wet. is there a cure time for it to harden? maybe a week or so? or should i turn the heat on in the garage to about 70?
thank you and sorry for long post
Steve
I would turn it up to at least 70, When i paint I will take it up to about 78 to get everything up to temperature, then turn it down to about 72 or 75, then leave it at 72 overnite or a couple of days, your shop temperature may say 70, but your metal could be a little cooler then what your thermostat says.
Rob
I will beadblast nuts and bolts, then spray them with a rattle can, then put them in a toaster oven for about 25 minutes, and that will dry out and harden the rattle can paint up.
I think the same principle in your shop, just turn the heat up.
Rob
It depends on which chassis black you used. DuPont makes one that is used right out of the can, no thinning, etc. PPG makes one that uses a little catalyst (16:1 ratio). If the catalyst was ignored, you would have a problem drying. If it is very high humidity, that would slow down the drying as well.
