I just got a Aeroquip braided steel fuel line and have never worked with it before. I am trying to cut it to the proper length. I wrapped it with electrical tape and am using a 32 TPI blade on my hacksaw. I am not sure wether to saw fast or very carefully and slow. I tried one practice cut slow and the line was fraying pretty bad. Is there a better way to cut the line or any tricks to cut it clean. Any help appreciated.
Thanks,
Greg Hauser
Try a cut off wheel on a die grinder,max RPM.Also use masking tape, won't melt as bad.They make a special blade for this purpose that can be used in a chop saw,that works the best.Hope this helps.
Brian Weil.
Wrap tight with masking tape, clamp cut area 1 inch from vise jaws, use a fine tooth hacksaw, grind frayed wires down on a bench grinder or trim with clippers.
A fiber cut off wheel that burns through the hose is better, but I've done plenty with a hacksaw and worked fine.
Be sure to clean the junk out of the hoses.
David
David's Motorsports page
First Gen Suspension Page
67 RS 327
69 Camaro Vintage Racer
65 Lola T-70 Chev 350 Can-Am Vintage Racer
I wrap tightly with duct tape and use a (new) 32-tooth quality Nicholson hacksaw blade that I don't use for anything else. I also use a set of aluminum "soft-jaws" with magnets in them that fit in my vise that are shaped to match the hex fittings so I don't scar up the fittings while installing them (grips 4 sides of the fitting instead of just 2, and holds them straight). A small flat-bladed screwdriver is handy for "tucking in" strands as you start to insert the braided hose into the fitting.
JohnZ
'69 Z28 Fathom Green
