1 - 2 of 2 Posts
I have a 69 standard coupe with V8350 automatic. It is in running condition till I can start resto. Recently the dash and running lights quit working. I replaced the light switch, no better. All fuses good. I can remove the connector to the switch and using a jumper wire can get all the lights to function. What am I missing?
When you say running lights, do you mean parking/headlights? I just fixed a similar problem where the dash lights went out due to a short that was caused by a defective headlight switch. Since you can manually get the lights to work when by-passing the switch, my guess is you have a bad or missing ground somewhere. It never hurts to make up a wire with some terminal ends that you can use to run a ground to the dash flex board.
1 - 2 of 2 Posts
