I have not dug into it yet. I've only taken a quick look. How do you remove the center panel from my '68 dash? It appears there are two screws on the underside. I did not see any others, so I assume there are clips up top behind the trim piece? Anyone got tips?
Jim
IIRC, the panel pulls straight out. It is held in by expansion clips.
This is just from memory when my Dad and I worked on his '68 Vert.
Discussion Starter · #4 ·
Thanks fellas. I'm thinking of fabbing up a carbon fiber piece to replace this panel. Then getting a Covan's piece for over the column. And fabbing a piece for the console. I'm torn between eliminating the center section opening for the vents (since my A/C and heater are gone), or keeping a stock look. If anyone has pics of their custom center section, I would appreciate seeing them.
Jim
