1 - 14 of 14 Posts
After i installed my electric fan, I drove the car somewhere. When it was time to go home (night time) when i turned on the lights the dash panel and all the gages did not have light. The head lights,brake light, dome light all work except all the light on the dash. Is there a fuse that controls just the dash.
Where should i start looking for the problem?
Discussion Starter · #3 ·
Hey David,
some of the words on my fuse box are rubbed off. I can barelly read some of them, like heater,radio, brake light....
Would you have a drawing diagram of the 69 fuse box?
Anybody..... Thanks in advance.
Discussion Starter · #5 ·
I tried to take out some of the fuses from the box, but the pins are kind of rusty and old and some of the fuses broke. So, now i need to replace some of them and noticed that they are different volts.
Are they all the same size but different volts, except the little tiny one at the bottom middle of the box?
Discussion Starter · #7 ·
It's not volts, it's amperage!.....Different fuses have different amp ratings!.....Do they even still make those old fashioned glass tube fuses??
Thanks for correcting me Ron. Ya, they still make them.I saw it Autozone the other day.Im going to swing by after work and pick some up. I need to know exactly which amp fuse goes where. A diagram of the fuse box would help.
Hey David,
The fuse you are looking for is the smallest length fuse in the fuse block on the bottom left side of the fuseblock. All of the other fuses are longer than this one so it should be easy to spot. It is the only fuse that is smaller than the rest.
David F.
Discussion Starter · #10 ·
Thanks David,
Im going to go pick some up right now. I will post tomorrow to let you guys know if it fixed the problem. Peace.
Thanks David,
Here's to hoping that fixes your problem:beers:.
David F.
Discussion Starter · #13 ·
Problem solved. Thanks guys.
It was the little fuse, nd one of the ground wires under the dash was loose.
Wooohooo. Now we can drink:beers::beers::beers:
:cool::beers::thumbsup:.
David F.
1 - 14 of 14 Posts
