Well I got the 1/4s in standox and I'm starting to fit the deck lid. Goodmark of course. It fit's pretty well. I had to do some adjustments on the rear lip but no big deal. The problem I have run into is, when you hold both side from the rear and try to tweek it a little the skins moves around the shell. Kinda like it was folded down around the edges but never glued. Can I just use Door panel adhesive aroung the edges or should I weld it
