1 - 2 of 2 Posts
I need to replace my oil pan and I have read the many helpful items on replacing an oil pan without pulling the motor. One thing I'm assuming is those were original size pans being replaced. Would I be correct to assume this trick could not be done with a deep sump pan with windage tray?
Depending how deep your pan is, windge tray bolts, pump sump, crank counter weight position , suspended height in the body , headers, and how much room you have behind the flywheel cover, yes, it can be done.
I have done this with the 6 qt Moroso pan.
1 - 2 of 2 Posts
