I am not running a heater core. Can I cap off the outlets from water pump and intake, or does water need to pass from pump to manifold. Currently just a have a small hose from pump going into manifold inlet. I want to clean up the engine compartment some.
Plug the holes. No need for any bypass hose to clutter up the engine.
If its a big block..you can ditch the bypass hose and install a bypass stat.
If its a smallblock..the bypass is intregal to the pump/block and a standard stat will suffice.
