· Premium Member
Try Casper Electronics. I recently purchased a TPS splice harness from them. It plugs into the TPS and provides a connection to my variable speed fuel pump. You may need to call them to make sure you get the right connector.
  • Helpful
Reactions: srode
Discussion Starter · #5 ·
Thanks Guys, you did better than I did.
Don, that's what I thought but if you look close at the picture the the indexing on the plug is upside down vs this one.
Pat, the one you posted looks the same, and Steve I found one on that link that looks the same and it says coolant sensor. If this type plug is only supposed to plug into a sensor and not another wiring harness terminal then I may just need to cut it off and use a different plug - I thought I might be able to find something that would work with it but that may not work out.
I may give Casper a call Steve, to see if they can come up with a solution.
