1 - 2 of 2 Posts
I have a set of door panels & the cardboard backing is in poor shape were the rug goes & areas were the clips hold the panel to the door. any way to repair this so I can secure the panel to the door without damaging the panel? replacing the carboard ideas is what I am looking for
Some materials used have been Masonite board, wall paneling, and luan brushed with Arthur Formby's Tongue Oil.
I was thinking of Formica, countertop sheeting. You can get a 4X8 sheet from Lowes for $40, cut four sheets from one sheet, glue two sheets together, and have an endless life panel.
When re-attaching the panel back onto the door, be sure the pastic sheeting is long enough and in good shape. It must fit into the groove/slot at the bottom of the door to prevent the panel from getting wet and to drain the water to the outside.
1 - 2 of 2 Posts
