Can someone please desktop dyno this setup
Sportsman II heads that flow 265in. 195 ex.
Victor Jr. Intake
Speed Demon 750 w/ annular boosters mech. secondaries
350- .030 over with a 400 crank = 388 ci.
New Eagle 4340 forged steel crankshaft ( Early Style 2 piece rear main seal )
New Eagle "ESP" 3-D H-Beam connecting rods ( Bushed Fit Pins )
New SRP 4032 high performance forged aluminum pistons, with pins and locks 11:1 c.r.
Premium Plasma moly performance piston ring set
Clevite 77 high performance H series performance rod and main bearings
XR274R solid roller camshaft, anything else you need?
Thanks a lot guys
Yeah need static CR. if it is around 11.1:1, I will say 415 to the rear wheels....
With your heads youre lookin around 450hp, better heads would help.
DesktopDyno 2000 says:
Assuming Large Tube Headers with Mufflers
2000rpm - 149hp 390torque
2500rpm - 195hp 410torque
3000rpm - 248hp 433torque
3500rpm - 305hp 458torque
4000rpm - 361hp 474torque
4500rpm - 414hp 483torque
5000rpm - 455hp 478torque
5500rpm - 473hp 452torque
Peak Torque : 478 at 5000
Peak HP : 473 at 5500
At the flywheel
