Is the difference in seats from the 711 Standard to 712 Deluxe interior more than the upholstery? Are the seats framework any different?
Thank you
The deluxe door panels require you to use deluxe window regulators as the door panels are thicker and the deluxe regs have a longer pin to connect the window crank onto. They are about a 1/2" longer and the old ones will not go through the thicker door panels once you upgrade. The rear ones are fine
hugger 69 did you have to drill any holes to add the deluxe inside door handels or do the bolt holes line right up to standard spots?
MKasier I see your just up the road from me, if you get all the deluxe door parts its just a matter of removing the standard parts and replacing with deluxe and getting the regulator adjusted.
Mike
