I'm wondering if standard 1968 tail lamps can be used on an RS if the lenses ae changed? I've reposted this as I was getting invalid feedback which was my fault because I didnt supply enough information.
Here's a link with the standard light. http://i138.photobucket.com/albums/q247/68camaropictures/camaro1017Small.jpg
I assume the RS just has another red lense on the inside. Can someone confirm this?
Thanks in advance, MJ
I would think it would likely be easier (and cheaper) to purchase new ones, as the originals are usually quite badly pitted. Personally I like the "Classic Headquarters" brand, they come with threaded studs and the required nuts to hold the bezels to the tailpan, and the chrome piece down the middle is a bit wider and looks better to me, likely closer to original. I somehow ended up with one CH brand bezel and one other unidentified bezel, the CH appears to be slightly higher quality, although either would be fine if they matched.
