Hey guys so I just purchased my 68 Camaro on Sunday. Now after looking over it for a Few days, I noticed the pass side tire seems to be closer to the wheel well(towards the front of the vehicle) pushed foward a bit. Is there a way to pull it back a bit. If so how. Do I need new leaf springs. Isn't there suppose to b a center eye for the leafs to sit on the track bars.
Could be as easy as you just need new spring pads (they locate the rear to the spring). If they're worn or loose, the rear can/will move.
That's what I'm thinking, a broken pin(eye) I had it on the lift last night and on the track bar there's a hole and if u look between the leaf spring n control arm there's nothing in between. Both parts are smooth. Ill just go ahead n pull the shackles loose n take a peek in there. I do hope is something simple or inexpensive. Thanks for the replies.
So I found a pair of used leaf springs for $100 should I just grab them. I'm thinking the ones that are on there now are worn. And the potential cause of my offset In the differential. Is $100 good or should I just buy new I ones.
