1 - 10 of 10 Posts
I can almost answer this question myself. But it's the only slot on my fuse box that it DOES work. where else should i try a connection for AC continuous?
OK I'm confused. Tail lights should only work when the headlights are turned on. Do the brake lights work when the pedal is depressed or the blinkers/hazards are engaged? The terminal location labeled battery should provide constant 12V from the battery, but I don't think that is what you need/want.
I have the Digi-Tails 1100167R - Sequential LED Tail Light Panel Kit on my 68 Camaro. This kit requires a dedicated 12 vdc battery supplied voltage to each light assembly to operate. I had to run a new wire from the tail lights to the fuse box and plug it into the BAT terminal. I tested the lights using a lawn mower battery positioned in the trunk. If that new additional wire is not used and connected to battery power (fuse box BAT terminal), lights do not work properly.
Discussion Starter · #8 ·
Changed out all the old fuses, cleaned the contacts and used the "fused" battery contact clip. working perfectly, like new and super bright!
Great. I loved the looks of mine when I tested them in the garage. Can't wait to get our car finished up. Getting close with dash about 20% finished. Just a lot of small things to do.
Discussion Starter · #10 ·
night and day isn't it? I have the front turn signals and dome lights on the way from Digi-tails, I'll post how they look when I have everything in....also going to get a good headlight...
1 - 10 of 10 Posts
