I pulled off a disc brake setup off of a 69 GTO. The only thing that was missing was the power booster. Is it possible to use a 75 Pontiac Grand Prix power booster on this setup (the reason I am asking is because I was given the booster and it looks practically new)? Is it advisable to get a remanufactured brake master cylinder? Or rebuild this one? The metering block is still attached to the master cylinder also, I am not sure it works though. The backing plater are rough and I want to purchase new ones. Do I need to specify 69 GTO when I order new backing plates or will the 68-69 camaro plates fit? I ordered all new ball joints and bushings for the front suspension. Will these fit the disc brakes spindles or will they only fit a 67 camaro? Sorry for all the question jammed in this post
Thanks for all the help!!
Kevin
67 Camaro rs
327?TH350/8.5" 10 bolt/3.73 posi
Kevin
67 Camaro rs
