Before I start this, let me say I have ZERO experience with headliners other than removing my original. I've never put one in, never seen anyone put one in, or even seen a reproduction in person before!
I picked up a Distinctive Industries brand headliner from Ecklers warehouse in Titusville, FL. The kit included the headliner, sail panels already covered, and sunvisor material. I opened the box while I was there for a quick look to compare the appearance to a piece of my original GM. It was a good match appearance wise. In the photo below, the three small pieces are sitting on the Distinctive sunvisor material.
After getting it home and really looking it, here's what I found..... and need some questions answered.
1) Compared to headliner sample pieces I got from TMI, PUI, and Legendary, the Distinctive was the closest in appearance to a piece of my original GM headliner that was tucked under and had never seen the light of day......The pattern of the TMI and PUI are correct but both have a little duller sheen than the GM piece. The Distinctive's sheen was spot on the GM. The Legendary sample was nothing like the GM......So appearance wise, the Distinctive is great!
2) Out of the box, the Distinctive has a very strong vinyl odor! Exactly like if you took a brand new vinyl shower curtain out of it's packaging and how strong it smells....I couldn't take smelling that every time I got in my car...….Is this normal? Do all brands smell that way out of the box and would it fade over time?
3) My biggest concern is how you would mount these sail panels. The original GM's had four brackets fastened to the back of the sail panel. A clip went in the bracket and then the clip was pushed into holes in the sail panel structure of the body. The distinctive sail panel has no brackets for the clips to fasten to. There are patches of reinforced cardboard on the back with small holes in it. My guess is maybe you are supposed to put your clips in these holes. The problem with that is that first off, you need four clips per side and there are only three holes, the holes are too small to put an original clip in, and the holes are close but not in the same position as the clips on the originals. Two of the at least an inch off! I have no idea how I would mount these.
So I'm needing opinions on this Distinctive headliner and sail panels. Is what I'm seeing here (and smelling) here the norm with all manufacturers or should I return these and look for something better?
Thanks.....Dave
ps....For what it's worth, I measured the thickness of all the samples I have here. I'm not sure if the differences are significant.
TMI .0210 inches
Distinctive Industries .0220 inches
My original GM .0235 inches
PUI .0240 inches
I've heard from some people that they use Velcro to mount the sail panels. My repro's from Classic Industries were just like the OE sail panels, down to the slots for the mounts......
Discussion Starter · #3 ·
Do you remember who the manufacturer was of your headliner from Classic?
Did your sail panels have the same metal brackets as the OE on the back that you slide the mounting clips into or something else that they slide into?
Thanks....Dave
Discussion Starter · #4 ·
My guess would be there is a ton of people on the forum headliner experience.
Any more thoughts on this? My biggest concern is installing the sail panels. Do all brands of sail panels on the back look like the one from Distinctive? Do some come with brackets for the push in clips like the original GM?
68lowered (Pete) said the ones he got from Classic Industries had the slots for the mounts. I don't know how long ago he got them but when I look them up on CI's website, it says the pre-coverd sail panels come with Velcro for attachment. The uncovered sail panel boards come with no hardware.
I'm still concerned about the strong odor too and if it would fade over time.
So I'm still trying to figure out what I have here with this Distinctive Industries headliner and sail panels. Something worth keeping or something I need to return and start looking elsewhere.
Thanks....Dave
