I have a 1967 Camaro with a point type distributer that was changed over to an electronic. The points type only had one wire coming out of the distributer. The electronic one has 2 wires coming out, a red one and a black one. Where do I hook them up? Thanks!
I think Bill assumes you have an HEI cap, which by your description you don't. Assuming you still have the separate coil, the red wire from the dist goes to the positive terminal on the coil, and the black goes to the negative side.
