My new 496 has a billet cam with a cast gear. I bought a MSD #8366 distributor and am trying to find out if I can use the gear that came with it or if I need to replace it. I know that I need a "melonized" gear but can't find any info if the gear that came with it needs to be replaced. I have not had a change to call MSD so hoping someone here could answer.
Summit has this part:
http://www.summitracing.com/parts.aspx?sku=MSD-8561
The gear looks the same as the one on my distributor but is it?
I would call MSD to make sure. I was interested in the 8394 from them, but wasn't sure if I needed to buy the melonized gear. Called MSD, and the guy said it is already installed on that distributor. Very polite, and virtually no wait on hold.
All of the MSD distributors right down to the lowly Street Fire are supposed to come with a melonized gear if it says "steel" on the gear material on Summit. I've got a Street Fire HEI I've run on both an old hydraulic flat tappet and a cast hydraulic roller.
I called them and it does come with the melonized gear. One less thing to buy!
