I was helping a friend rebuild his front suspension and noticed his steering arms were shorter than mine. After reading on davids page I discovered that mine were the manual arms. My car came with power steering. Do i need to change the arms, or what affects can i expect by leaving them on. I drove the car or about a year and it didn't seam to handle bad. I will be running the ZR-1 17x9 wheels on the front with 255/40, so maybe the longer arm will help with the rubbing I'm sure I'll come across. Any ideas?
68 camaro under restoration
http://www.touringcamaro.com
Tony Huttmer of http:www.racehome.com has had the same problem. He is using the same size tires I think, and the outer tie rod end hits the rim edge.
A short arm clears much better.
As far as I know the long arms are not used on normal PS systems. But my page info is based on observation and speculation. Not any hard and true specifications.
David
David's Motorsports page
First Gen Suspension Page
67 RS 327 Origonal owner. 69 Camaro Vintage Racer, 65 Lola T-70 Chev SB Can-Am Vintage Racer
Thanks David-
I think my car was originally a manual steering car. Some of the spare parts that came with the car was a manual box. Go figure. I guess i better start looking for some short arms.
