1 - 14 of 14 Posts
hello new member Mark....1983 camaro z28 T-tops ,5 speed stick...my 1st new car ,original owner...have maintained vehicle paint/engine etc...now time for trim redo as dry rot has ruined it creating lots noise and rattles...want to redo door,window and hatch seals ,seats,trim and felt etc etc....i'm no car guru just wanna keep my baby maintained...learnt thru experience if says fits my 1983 camaro Z28 online doesn't mean it will ..don't want frustration of wrong parts ...any suggestion and experience of what parts work and where to get knowledge to replace be great-fully appreciate...not everything is OEM or OER so dont wanna deal with poor fits and returns thankyou for any help Mark
Discussion Starter · #3 ·
can you post some photos to your camaro ?
Harry thanx so much for a reply....thought i'd get none your the only one ...i'm not computer savy enough to post photo's....could send via txting if would help ....basically just trying to locate the best /working kit for door panel rails ,window channel weatherstripping,seals and feltstrips found someonline individually and in kits just wondering if anyone has any experience/suggsetions as to whether they actually fit or not,,,they always say compatible but have experienced not always true....b4 i dive into this endeavor...never as easy as it looks ...lol..thankyou Mark
Discussion Starter · #4 ·
looking for triangle door window weatherstip corner front seal also called a door window seal triangle....its the component that the front triangle weather strip filler , also called side window seal channe lfits into...any idea of companies that may carry it ..can only find used on E-bay...any help appreciated
Discussion Starter · #6 ·
have checked jeggs , hawks,a1/auto,tamraz.summit,classic industries,.....tyler at hawks motor sports most helpful of all...i guess part is WINDOW TRACK CHANNEL/MIRROR BRACKET...also informed me 1982 /1983 camaros have a bracket that only fits them for some reason not all Gen.#3 camaro's ...go figure ..so not many available and good luck finding new...this is the part i really need....mine is dry rotted ...any help suggestions appreciated... thanx for reply..Mark
Discussion Starter · #7 ·
i have seen softseal and metro weatherstripping at vendors, can find about every weatherstrip except my window track channel bracket ...which has brackets attached to seals...
Discussion Starter · #9 ·
thankyou a gr8 start ....will need most seals for my 1983 camaroz28...having hard time locating Window Track Channel/Mirror Bracket for 82/83 yrs.....pls let me know if better vendors for seals..i've heard different manufactuers do better than others,but don't know which ones!!!!...thanx so much for input
1 - 14 of 14 Posts
