I started removing the door glass last night and I noticed that a couple of the bolt heads that hold the door glass regulator assembly in there have some kind of black putty covering the bolt head. Had to use a screwdriver to pry it off. It came off easy but I was wondering what the purpose of this was and will I need to replace it?
Joe
They use that over screws that are not covered by the watershield..too keep moisture that collects on the door shell from collecting on the cardboard door panel. It's not totally necessary..whatever you want to do.
Discussion Starter · #3 ·
Thanks Panther, I didn't notice them when I took off the door panels last summer. Makes sense. I probably won't put it back. Hopefully this car will never see a rain drop but then again when shes finished I do plan on driving as much as possible. Thanks again for your help.
Joe
I found my car had the same putty or whatever it is on the bolts for the tracks for the quarter windows. You could still clearly see the persons thumbprint on the putty!
Jonsey, it sounds like one of those programs on TV..Cold case files...
'He commited a terrible crime in 1968.An auto worker at the Norwood plant kills a fellow worker by fatally stabbing the man with what appreared to be a rocker panel molding.. There was little evidence. The case went cold..Then, in 2003, a guy restoring his 69 Camaro find a fingerprint of the guy in the winder regulator bolt sealing putty!" "Finally, justice was served!"
Maybe I could trace the fingerprints and track down the guy that built my car and he could tell me all about it. :D :D
You don't need to remove the lower track bolts to pull the glass just the upper ones and the stops. The repair manual does not mention removing the front stop, but you need to remove it too.
