I bouight a set of tri-y Thorley headers for my 67 350. The header on the drivers side fits good, 1/4" clearance on the steering box and 1/4" clearance on the oil filter.
My problem is that the collector flange on the other side hits them floor pan. To the best of my knowledge I'm useing the correct motor mounts and cross member tower mounts.
The tranny crossmember was hooked to a Saginaw 3 speed originally and this is what I'm now useing with a super t-10. I was told that this crossmember should work. Is there a different crossmember that would lower the trans. tail about 1/2'-1' thus dropping the collector flange down away from the floor pan?
I've only got about 1/4' of clearance between my HEI dist. and the firewall at this time. Do I need to go to a different dist. if I drop the tranny tail?
[This message has been edited by tdks (edited 11-13-2001).]
