I am working on a '67 Camaro and need to reassemble the rear drum brakes. It seems like it shouldn't be that hard but when you have a pile of springs, brackets and levers it doesn't reassemble intuitively.
This morning I realized I have in storage a pair of built drum brakes. I pulled them out and below are photographs. To differentiate between RH & LH side note the emergency brake cable goes toward the front of the car.
I figured this might help someone else.
Exit: The RH side is identified as incorrectly assembled. The photo has been deleted and will be reposted when the assembly is corrected.
