If you suspect all or most of the lifters are collasped, I would first try to back off on adjustment and let motor run,if it will. Try to get them to pump back up and then readjust. They could have been adjusted too far down . If they won't hold pressure, then I would try to take each one out and apart and attempt to clean . Many times the piddle valves and disc become clogged or stuck from setting up with gunk. Put them back together and readjust , give them a chance to pump back up. Marvel oil is good here on assembly.
What you would want to try to do is keep those lifters if they are not worn out at the bottom and on the matched cam and cam lobe . If that don't work, its cam time with new lifters.
