Hi. A few years ago i had my 10 bolt rear end swapped out for a 12 bolt rear end with multi leaf perches. At the time I had ordered the wrong multi-leaf shock plates and ended up just re-using my mono-leaf shock plates. I have the hotchkis 1.5/2 inch lowered suspension. It is close to the wheel but there is enough clearance. Now i am going with a wider wheel with more backspacing and am going to have to change to the multi-leaf shock plates to get the extra bit of wheel clearance.
When these are changed can i re-use my same u-bolts or do i need to put new ones? How difficult is it to change these myself? Thanks for the help. Nick
