1 - 20 of 65 Posts
Ok members, I have a problem with my cooling system. It runs between 180-190 on hyway, and around 200-210 around town. Now I understand that I have a airflow problem at lower speeds. So, here's what I have, a aluminum radiator, measures:
26.00 wide
19.00 high
3.00 thick
Core size:
21.00 wide
19.00 high
2.25 thick
And to cool I have a offset 16" fan, the reason for the offset is my problem. I only have 2.3/4" from face of radiator to the fan pulley.
So, what I'm thinking is the 2 fan set up that would work for me.
Anybody have any thoughts on a setup that would work?
These Spal fans are pretty decent. Don’t get too wrapped up in cfm ratings because it is very easy to generate huge numbers as many manufacturers of cheap fans do. Spal can be trusted imho...
Make sure you can supply enough current to drive them.
https://www.summitracing.com/parts/spu-ix-30102052/overview/
Make sure you have sealed the gaps between the radiator and core support before spending money on new fans. Upper and lower closeout panels might help too.
Don
What Don said^^
Funny - have the same exact problem as you. Just guessing that you are running a Vintage Air front runner system?
I am in the process of having a custom low profile shroud made from C&R racing, but I am trying to cool a 572 BB.
Do you have a shroud now or just a fan mounted to the core?
Reactions: wireboy355
It never occurred to me that you likely don’t have a shroud as suggested by Greg and that the other half of the radiator is open. That is less than optimum and likely why it runs hot. A lot of under hood hot air is being recirculated. Dual fans covering the entire radiator is the way to go imho.
Don
Flex-o-Lite FLX-238. It is a 16 inch single fan that would replace your single fan if clearance is the issue with a dual fan set-up. It moves 3000 CFM of air. Do you have A/C?? What specific set-up ?? 2 3/4 inches clearance from face of radiator to water pump or are you running a belt driven fan also ? You mention fan pulley.
What Don said^^
Just a fan mounted to the core. I made a shroud in the beginning and mounted it, then the fan wouldn't fit into the opening.
Oops forgot to mention that I have Vintage Air AC, so condenser is in front of radiator. The 2 3/4" clearance is from face of radiator to fan pulley bolt heads no driven fan.
Thinking about removing AC, only use the heater and defroster option on it anyway.
Post up some pics of your set-up. Hard to believe that small block is that tight. Definitely need a shroud!
If you are interested, I have my Spal single fan with custom aluminum low profile shroud available that I just took off my car Saturday. Has 200 miles on it. Give you a good deal. 3 speed fan. Pm me
Reactions: DT
Discussion Starter #9
Some pics
Wow you are tight! Why not use a std fan set up with a stock shroud?
Reactions: rp930 and DT
Are you that tight because of the A/C set-up ?? Long water pump ?? Can you use a short water pump with the correct brackets etc to get more clearance ???
Some pics
The single fan without a shroud is not going to do the job.
The Spal dual fan setup posted by Don would be much better and should clear you WP pulley
Discussion Starter #13
Everything is set up for long water pump, would have to change everything, ps, ac, bracket just to gain about 3/4".
Discussion Starter #15
A little more info on my current setup,
16" Zirgo fan up to 3000cfm, its centered in the radiator just to the upper part of the radiator so the motor assembly clears the pulley. So that only leaves about 2" on each side that is not covered and about 3" on the lower side.
That gap around the fan is likely recirculating a lot of hot air from under the hood. Not good imho...
As I said earlier don’t place too much faith in cfm numbers. How much current is that fan consuming, it should be quite high for the claimed 3000 cfm.
Don
Discussion Starter #17
Any thoughts as if I do away with the ac condenser in front of the radiator, that that would give me that much more air flow? Even at slower speeds?
With adequate fans and a good shroud the AC Condenser is not a problem.
I don't think removing is and leaving fan as-is will solve your cooling issue.
X2. Fix the root cause.
Don
Reactions: DT
Discussion Starter #20
But I did some checking and the Spal fans that Don suggested is a little over 4"" where I only have 2 3/4"
1 - 20 of 65 Posts
