1 - 20 of 24 Posts
Will the factory dual feed gas line from a 69 Z work with a street avenger carb on a 350 small block? I think it should....if it does what about a filter? Thanks
I believe if both carburetors have metering blocks on both the primary (front) and secondary (back) of the carburetor, the duel line "should" fit.
As to the fuel filter, the stock setup was an inline 3/8" filter inserted in the rubber fuel hose between the metal fuel line that terminated on the sub frame and the inlet to the fuel pump which would work fine for you.
I thought that was the case, and I'll check into the correct filter that will fit between the pump and the frame....I am also using an aftermarket Holley mechanical fuel pump, but Im sure the fittings should be close....
They say you should never place a fuel filter before the mechanical pump. The factory used the brass filters in the inlet fitting on holley's. I have never used them, as they seem to be very restrictive and will plug easy.
I use a fliter screen coming out of the sender and then going to the hard line on the frame rail
Just curious who "they" would be? :confused:
I'm sure Scott is probably thinking what I'm going to say...
Any filter before the pump is having fuel pulled thru it whether its at the pump or in the tank unless of course you have an in-tank "pusher" pump. The factory puts a sock on the sender in the tank to filter debris to keep it out of the pump.
Jeff
Screen (100 micron etc.) is OK before the pump.
Filter (10 micron) is not.
Filter before the pump is a restriction (becoming more restricted as it collects crud) and can cause cavitation. Pulling a vacuum on the inlet side also lowers the boiling point of the fuel and can contribute to vapor lock.
About all you can do for a true low micron filter if you want to run one sadly is cut that pretty hard line and insert one in it. I think the factory filter was probably not a fine micron rating. Those plastic/paper ones are somewhere around 75 micron so they have less chance of issues when installed on the pump inlet. Carbs are a lot less sensitive to crud than EFI which is where the low microns come in. The brass filters used in the carb inlets are 40 micron.
I understand the reasoning on a filter after the fuel pump rather than before IF it is a fine micron rated filter. I don't think the one I referred to is such and the NAPA web site doesn't specify so the next time I'm at my local NAPA store I'll find out.
The repro Z/28 line set is a good choice for a 4150 Holley and a Perf RPM reg or Air Gap along with a factory style fuel pump. I had to modify it a bit when I swapped to taller Z/28 - LT-1 style valve covers due to the taller v/c gasket rails on aftermarket heads.
I have doubts as to whether it will work w/o modification using the Holley fuel pump unless the Holley pump puts the outlet exactly where it is on a factory pump and has the same threads... at least that kinda stuff never works for me.
I have been using just the sintered bronze filters behind the fuel inlet nuts for years w/o issue. They have never clogged. I don't drag race it. I don't believe GM used a filter just ahead of the pump on the Holley equipped cars.
The NAPA filter you listed is the same as a Wix 33033 which is rated at 20 microns. Googling around, I found a Holley TBI install sheet that includes one of those that gets installed before the electric pump and has a 10 micron after the pump. So, you'd have to assume that it would be OK before a mechanical pump.
BTW, most "name brand" gas stations use a 10 micron filter on the pump so you've gotta work pretty hard to clog up your fuel system regardless.
The '69 Z fuel line kits use a different size inlet fitting than the over the counter 4150 carbs come with. You can get the right inlet fittings on ebay and probably Summit or Jegs to make it work.
I've run an AC style canister fuel filter mounted between the hard line from the tank and the mechanical fuel pump for over 15 years on my Camaro and close to 10 years on the Nova with no adverse effect. Mounted them that way back in the day when these cars were daily drivers too and never a problem!
Yes Dennis the inlets are smaller, I think 5/16 inch. They are about fifteen dollars or so. I have not seen them anywhere other than resto books, or ebay. Have not seen them in Jegs or Summit. My car only had the filters in the inlet. Big blocks and small blocks without a Holley had inline filters. The carb lines will work with no problem, just connect them all loose and tighten after all are together. The pump to carb line might need some tweaking with a aftermarket pump, but most of those pumps have a base that can be turned, so maybe it will not be that bad. Works fine on my car, I have the factory intake, with edelbrock heads.
I used re-pop Z28 fuel lines on the Street Avenger on my 327. It works fine. I had to swap out the inlets on the Holley to make it work with the 5/16 lines.
I got the 5/16 inlets from Summit. http://www.summitracing.com/parts/hly-26-27/overview/
Discussion Starter #15
Thanks Guys, and Thanks for the pics Farm Boy, thats exactly what Im looking to do....I can't imagine the 5/16 lines would effect the performance either on a small block...
Discussion Starter #16
@ Dennis, If I use the AC canister filter shouldn't I be able to order a factory style steel line like some of the lower HP cars used? I remember seeing them on 350's and maybe even 396's....Correct me if Im wrong ? Thanks
Chuck, I believe what you are thinking of would only be for a single inlet carb and have a return line plumbed into them.
I don't know what year first gen you are working on but if it's a '69 with the alternator on the passenger side then the hard line from the pump to the brass Y block goes behind the water pump and there would be no room for an inline filter anyway. Farmboy's 327 has the alternator on the driver side making room for the hard line to fit where he has it. As well it uses a short water pump so the hard line won't fit behind the water pump like the '69 does.
Steiner, before I got back and read your post I called my NAPA store and they told me that filter is a 20 micron as well. Between the 10 micron filter that most "name brand" gas stations use and the fact that I do check and/or replace my fuel filters when the begin to show signs of becoming at all restrictive, I feel fine keeping it setup this way which seems to be your feeling as well. Thanks for your input :thumbsup:
Discussion Starter #19
DJD....thanks for the reply, my car is a 68 with the Alt. on the drivers side and a short pump. I plan to research the 68 Z fuel line to see if it may be an option and if there was a filter in place from the factory, and where it was in the line. I think if I tweak the fuel lines with a tubing bender between the Y block and the carb body I can resolve my clearance issue with the a/c bracket and hopefully move forward from there. I plan to order the pieces Farm boy mentioned and that should fix that problem. All the replies are much appreciated, and hope i can return the favor in the future!
Nope. The stock Z/28 setup only used the bronze filters insided the fuel inlets - no external filter. :thumbsup:
:beers:
1 - 20 of 24 Posts
