What's the easiest way to tell if I have an 8.2 or 8.5 rearend ? I know the rear is not original to the car. It's a 10 bolt with 2.73's. Which is better & why ?
thanks
Here's some good info. Basically 2 ways. By looking for squared off "lugs" on the bottom of the housing or by checking which size pinion nut it has (8.2 has 1 1/8 and 8.5 has 1 1/4). Here's the link: WWW.NOVARESOURCE.COM
P.S. Look under site map then under axel codes. There is some good pics there that will help too.
[This message has been edited by Winch (edited 08-06-2002).]
The 8.5 is the best. It can be built almost as strong as the 12 bolt. If you have the cover off you can check the ring gear bolts. The 8.2 has 9/16 heads and the 8.5 has 3/4 heads.
'69 RS/SS396 pro street
427/4spd/9"
Byars Performance
High Performance Drive Train Parts And Service
www.lubedealer.com/biggearhead
If you know it is a 10 bolt , can't you tell just by looking at the cover with the 8.5 being fairly smooth and round except for a little protrusion where the ring gear is? The 8.2 would have the large upside down "V" visible on the cover( same as a 12 bolt).
Am I correct or not? Just thought this would be easier ID than pulling cover.
Guy
<BLOCKQUOTE>quote:</font><HR>Originally posted by gjohnson:
Guy
<HR></BLOCKQUOTE>
I have 2 8.2's one has a smooth cover, the other has the "eyebrow". both are 1 1/8 pinion nuts. The smooth coverered one codes to a 71 Nova, opened it up and as stated by BGH the ring gear bolts were 9/16 heads. Back to the yard.
My '68 Camaro
Doug G.
68 Camaro
406 ci.
[email protected] W/ 2.73POSI.
One thing that seems to be peculiar about these rear ends is the published interchangeability. I was at the junk yard just the other day and asked for all the possible interchanges for a 73 Nova... here is the list I was given:
Camaro '67-69 10 bolt cover
Firebird '67-69
Nova '68-71 10 bolt cover
Nova '72-75
Nova '77-79 11x10-1/4 cover
Apollo '73-75
Omega '73-75
Omega '77-79 11x10-1/4 cover, 9-1/2x2 brakes
Phoenix '77-79 11x10-1/4 cover, 9-1/2x2 brakes
Ventura II '71-75
Ventura II '77 11x10-1/4 cover, 9-1/2x2 brakes
That it!
Several things caught my attention on this list tho: First, there is no distinction between the cars that are known to be 8.2" versus 8.5", so they must only be concerned with it fitting in the car properly. The second thing that sticks out is that fact that none of the cars listed include the '76 model year! Any body know why that is? 76 model year list includes all the different makes list above as being interchangeable, but only with other 76 models.
Also, I didn't see this picture out on the site referenced above, so here is a decent picture comparing the rears: http://www.chevelles.com/showroom/rears.jpg
good hunting...
Bill C.
Bill C.
Colorado Springs, CO
68 Camaro... someday!
71 Chevelle SS
70 Nova
[This message has been edited by BC (edited 08-07-2002).]
