1 - 10 of 10 Posts
Whats E-coat? I have an uncle that owns a powder coating and jet-hot coating in Fresno area.
70 Camaro 307cid(350soon) /350th ex. dark purple (dark blue soon) in. black
74 Trans Am 400cid/th400 ex. red in. red power windows tilt wheel
E-Coat is a black matte finish preservation material used by G.M. on sheet metal parts before they were shipped from the factory.
Sorry I can't help. The only place I know of is in the Detroit area.
E-coat stands for a type of anti rust coating. It is an Electrodeposition primer that is still used to this day (although the current generation is a light grey color).
E-coat is applied by dipping the grounded (or charged) part in a charged (or grounded) E-coat bath. The electrical current deposits a uniform film over the metal.
Steve - Central Ohio Camaro Club
'69 Camaro RS/SS-350 - Daytona Yellow
'95 Camaro Z-28 - Sebring Silver
click here to see my webpage ---> My Camaros (updated 11/5/01)
E-Coat is short for "Electrophoretic Deposition" of primer, which is the process used by all assembly plants worldwide to prime complete raw bodies after they're hot-cleaned and coated with iron phosphate (to provide "tooth" for the primer).
The complete body, hung from a moving overhead conveyor, is submerged in a 60,000-gallon tank of water-based primer, with the body positively charged and the tank and primer negatively charged (high voltage, low amperage) for about five minutes, then drained, rinsed, and baked. The attraction of the opposing electrical charges ensures that the primer film build thickness is even everywhere on the body, even in enclosed box sections.
Surfacers, sealers, and color and clear are done later in sealed, temperature- and humidity-controlled downdraft booths by robotic spray machines using high-voltage electro-static "bells", not spray guns, which spin the paint off a 4"-diameter disc spinning at 10,000 rpm, where the body is charged one way and the disc is charged the other way to attract the paint directly to the body surface and minimize overspray losses.
All paint (except the clearcoat) is water-based, so all the miles and miles of paint plumbing, pumps, valves, and tanks is solid stainless steel. All of this operates at about 80 bodies per hour - an assembly plant paint shop is the most expensive real estate on the planet (about $750 million for a typical assembly plant paint shop).
This E-Coat process (just the primer portion) is now done on a small scale (tank just big enough to hold one car body) by an increasing number of small aftermarket shops, usually in combination with a chemical stripping process first, like the shop in Detroit.
JohnZ
'69 Z28 Fathom Green
The jet hot is a coating used on headers that gives a chrome like finish but will not turn blue like chrome when heat is applied. That doesnt sound like what your looking for though. I dont know of anyone that does E-coating, though I have heard of car bodies being dipped in an acid to strip off all oils, dirt and other contaminents. That costs upwards of $2500 for a body last time I read about it.
hhmmm...a jet hot coated body. that would be neat. that sucka would shine.
355sb, vortec heads, HOT cam,T-10 tranny, 3.70 gears 16X8" IROC wheels
see pics here http://community.webshots.com/user/novaderrik
What cost does the e-coat demand? It certainly looks like a good process for a valuable car.
Rick Dorion
69 RS Conv,355,M20,4.10's and I don't worry about stone chips.
Wouldn't it be cool to e-coat your entire car after stripping it? I had my car dipped and it did a great job of removing every trace of paint or primer or e-coat from every single spot of metal on the car. The challenge was getting some kind of primer back on the metal. A big 'ol e-coat dip session would have been great.
Scott
'69 400SB, Richmond 5-speed
www.geocities.com/sdenning1
1 - 10 of 10 Posts
