Has anyone used the Engineered Components (ECI) disc brake conversion package that they offer for Camaros? They are supposed to keep the wheel mounting surface in the same location as the stock drums, and the kit uses the stock drum spindle with no modification needed. It uses their own custom billet hub, with GM Camaro/Firebird rear 11 inch rotors, 78-81 Camaro calipers, and standard D52 pads. I like the idea of mostly off the shelf parts that can be picked up at any local parts store if needed, along with the fact that it doesn't push the wheel outboard 5/8" like the stock disc brake rotor does.
Here is a link to them - you have to scroll down for the Camaro kit:
Engineered Components, Inc. - Your One Stop Brake Shop!
Another kit I am considering is the Wilwood 140-10996, which says it only moves the wheel .19" outboard, so that might work as well. The Wilwoods are well known as being a good kit, but I do like the idea of using GM parts. Looking for any input from TC members - thanks!
