Terminator X Stealth EFI, Where are you guys mounting the ECU? I have a smooth firewall but would the under hood heat be an issue? Where are you mounting yours?
I have an aluminum glove box insert, my ecu is on the back side of that.
gut if you have vintage air, that space isn’t available
Have put a small false floor on the passenger toe board. I can just pull up the carpet at the corner to access it if needed.
