1 - 2 of 2 Posts
I am installing a new air gap manifold on my small block. The alt bracket does not work because the water goose neck is 1 1/4" taller than a stock manifold. I also have vortec heads but everything seems to fit ok on that end. It looks like they have a tapped out hole for a bracket in the manifold at the same height as the stock hole however it is a different location, I think I can cut the stock bracket and drill another hole, but I don't want to try it untill I ask someone who has run into this problem before. Thanks for your help!
you could just cut off that part of the bracket that is supposed to bolt to the intake. it should still be pretty stable.
355sb, vortec heads, HOT cam,T-10 tranny, 3.70 gears 16X8" IROC wheels
see pics here http://community.webshots.com/user/novaderrik
1 - 2 of 2 Posts
