1 - 12 of 12 Posts
here is a quick question for u guys on an edelbrock carb wich one of the two adjuster screws on the front is for fuel and wich one is for air.????
69 Camaro RS, 355ci, 71 gm heads 74cc 1.72in 1.50ex,mild cam, Preformer rpm intake, edelbrock 600 carb, 350 turbo w/ shift kit 2500 stall, 12 bolt 4.56 posi..
if I am correct, the two big ones both meter the air and fuel mixture... one for each primary. The screw to the far right is the idle speed adjustment.
1 - 12 of 12 Posts
