1 - 8 of 8 Posts
O.k so the Holley Hp efi is ordered (multi-port), tank ordered, hose ,filters ,fittings on their way. I "think" I got most of it figured out. (ya right!)
The throttle is scaring me a bit. I have linkage now. Do you think it might be possible to modify it to work? If not, what parts should I look into? What works for you? I have committed to a roadtrip on the 12th. I want this in. Being from Canada,special parts can take over a week to arrive. Not cool when you have a dead line!
Dan, what rear gear/tire are you running, and which TKO OD do you have?
Just curious how your motor runs in OD.
Vince, 3.73, 255 45 18's (26.5 tall), .64 od. It cruises around 21-2200rpm . It's happy there. I think I would consider trying 3.55's one day but that day is far away.
Rick, what intake is that? I didn't think the rails would sit that low. Thank you for the picture.
That's exactly where I cruise...I think you will do great with this system.
It's an edelbrock Pro-Flo Intake
Hey, camaro67, I like the way you did the linkage. Can you tell me how you did this...parts list and supply?
Thanks much. BTW, here is my current set up with a proflo2
I got may parts from Grainger
2- Spherical Rod Ends 1/4 x 20 Thread # 6G171
1- Threaded Rod Class 1A HighStrenght # 2GrA2
2- 1/4 x 28 x 1-1/4 Cap Screw & Nylon
Locknut.
Chrome covering is from an extra dipstick tube
I had laying aroud.
Hope this helps you
1 - 8 of 8 Posts
