Ok I have a taurus fan,I know it is 2 speeds,i will wire in 2 relays.I want the fan to come on at 200 off at 185.I don't want manuel control.what I want to know is what determines when the hi and low speeds come on?Should I just wire hi speed only? Looks like when it gets to 200 the hi speed should come,if so,why should i wire the low speed.Also are the temps ok?
Discussion Starter · #3 ·
Thanks Toofast,I was thinking maybe the low speed would be all I needed.I think I can do one or the other.Anyone running just the low speed,if so does it cool ok?
I have the same fan, had the 408 big block in last summer with an aluminum radiator, no problems just running on low. I thought I would have to hook up the high speed but haven't needed it, ran 180 to 190 with a 180 thermostat, even with outside temps 100+. :beers:
